pure coolant to the reservoir or?
100,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
CYRUAROEDDING
  • 10 POSTS
Okay, so I was changing my valve cover and needed to remove a coolant hose and when I was putting everything back together and was going to refill the coolant I noticed some leaves entered the coolant tank when I took the cap off.
I then removed the tank and rinsed the leaves out with distilled water and vacuumed the connecting hoses just in case some debris fell into the hoses. I then reassembled everything and decided to flush the coolant.
While it was draining I added a gallon of distilled water to flush more from the system.
Then I bled the system and ran it for a bit.
I ordered a refractometer to get the coolant concentration I desire.
Am I able to add pure coolant to the reservoir or do I need to add premix?
When I drained about half remained in the engine.
Sep 26, 2025 at 3:30 AM
  • 55,710 POSTS
Yep, this is difficult to tell sometimes, I always like to stay on the side of pure coolant for the ultimate protection. Let us know if you need anything else.
Sep 26, 2025 at 11:29 AM
KRAKENAUTO
  • 113 POSTS
There is no need for premix. Use the pure coolant, then top it off with water to your desired concentration. Premix is just diluted prior and not necessary in this scenario.
Sep 27, 2025 at 1:50 PM
