Coolant
1,361,500 MILES • 4 CYL • 2WD • MANUAL
LA.VERO
  • 43 POSTS
Before i drive i need to add to tank i park and leaks. The Saturn book says to only add 50/50 DEX-COOL coolant. I cannot find it any where. Is there any other kind of coolant i can put in? Please help.
Nov 5, 2017 at 10:57 PM
STEVE W.
  • 15,399 POSTS
Not without causing problems like gelling coolant and plugged systems. I would fix the leak, then while you have the coolant drained for that flush the system real good and re-fill with common green coolant. You will need to service the system more often but you can use common antifreeze.
Nov 6, 2017 at 12:16 AM
LA.VERO
  • 43 POSTS
Thank you and for this year of car coolant goes in the tank right? I cannot tell where it is leaking from. When i did check it was wet around the cap on the tank but i see drips from the middle front area.
Nov 6, 2017 at 12:23 AM
STEVE W.
  • 15,399 POSTS
You are correct. Leaks can be difficult. You can rent a pressure testing tool from many parts stores that can help. You fill the coolant up cold and put it under pressure, then look for the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Then you look at every hose, radiator, water pump and coolant location for any sign of a leak.
Nov 6, 2017 at 8:19 AM
