Codes p300 and p302
2003 VOLKSWAGEN PASSAT
190,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
ZTRETTER
  • 5 POSTS
Engine light flashing. Runs rough. Doesn't want to accelerate. Just got a coil and vacuum tee replaced. Ran good until yesterday. Codes p300 and p302 came up as it did the first time. So obviously those have to be replaced again. Is there a deeper issue? Where is the vacuum tee located? Any help would be appreciated.
Jan 11, 2020 at 12:27 AM
  • 110,240 POSTS
Here is what I suggest. Since the coil was already replaced and the same codes came back, I feel there is more to it. As far as the location of a vacuum T, it could be anywhere. Here is a link that explains how to check for vacuum leaks. You can use this to locate a leak:
Is it possible for you to get your hands on a live data scanner? I would really like to know what the short term fuel trims are. I can explain how to get them if needed.
Since the misfire remains at cylinder 2, it could be an injector issue, low compression in that cylinder, fuel pressure, and so on. If possible, remove the spark plug in cylinder 2 and let me know what it looks like. For example, what color is the electrode, is it wet with fuel, and so on. However, before you do that, I suggest checking to make sure there is spark to that plug. Here is a link that explains how to check for spark:
Do these few things and let me know what you find.
Jan 11, 2020 at 8:53 AM
ZTRETTER
  • 5 POSTS
I switched coils with cylinder 1. No change. I switched plugs with cylinder 3. No change. The plug did look a little wet. Like it had oil or fuel on it. I'm going to check spark to the plug today.
Jan 12, 2020 at 1:59 AM
  • 110,240 POSTS
In addition to checking for spark, check compression on that cylinder. Make sure it isn't low. That can cause a misfire as well.
Let me know what you find.
Jan 12, 2020 at 8:38 AM
