Cooilng Water System leaking
180,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • AUTOMATIC
AHMAD RAMLAN
Every 2 or 3 days I have to topped up the cooling water in the Cooling Water Tank.
Suspect leakages of the cooling water piping situated at the back of the engine.
Do I have to to shift up the whole engine out for this repair? as I was told that there's no room underneath to do any repairing or replacing the piping.
Please advise further.
Oct 13, 2019 at 4:55 PM
  • 110,248 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US, so my technical information is very limited. Can you tell which line is leaking? Is it a heater hose?
Oct 14, 2019 at 12:44 PM
AHMAD RAMLAN
Not sure actually where the leaking was originated from. But drops of water found on the floor right underneath the engine.
Cooling water pump was recently replaced. Every 2-3 days need to top up the cooling water reservoir tank by about 500 ml.
Oct 14, 2019 at 1:05 PM
  • 110,248 POSTS
Welcome back:
That could be from several different places. Try pressure testing it to see if you can cause it to leak and then follow the leak to its source. Here is a link that explains how it is done. You will need a pressure tester, but most parts stores will lend or rent one to you.
https://www.2carpros.com/articles/radiator-pressure-test
Here is a link that you may find helpful:
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know what you find.
Oct 14, 2019 at 1:55 PM
