Convertible Top Relay
194,000 MILES
SPACINJMAN
Where is the Convertible Top Relay located on a 1988 Chevy Cavalier Z24? My top stop operating and I need to troubleshoot this to find out the problem. I checked the fuse which is fine. It is on the same circuit as the windows. How would you test the Convertible Top motor if the relay is good?
May 20, 2013 at 5:41 AM
DOCFIXIT
  • 18,828 POSTS
check for voltage at motor when switch activated
May 20, 2013 at 6:17 AM
SPACINJMAN
Had everything tested... power to motor is good and motor is also good. So I still need to find the Convertible Top Relay. I can not locate it.
May 30, 2013 at 1:19 PM
DOCFIXIT
  • 18,828 POSTS
Could not find relay but did find power comes off power window circuit breaker
Jun 4, 2013 at 1:36 AM
