Convertible Top Luggage Barrier Sensor?
18,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
MMALLORY
The convertible top will not operate, message is "only manual operation possible". Error code read is that the "luggage barrier sensor is open". I need to know where that sensor is and how/where it is connected.
Feb 3, 2024 at 12:11 AM
MMALLORY
Never mind. I solved my issue. The sensor is inside the right-side luggage barrier pin/post. I took that off and saw that the cable was disconnected from the backside. Plugged it back in, attached the pin/post and top works as it should.
Feb 3, 2024 at 1:21 AM
  • 55,721 POSTS
Good job, sorry we couldn't get to you sooner.
Feb 3, 2024 at 2:44 AM
