Bought it as is. No sound of motor or hydraulic, only thing that moves when I press the button is all windows go down a bit for the top to open. No codes I can see. The trunk was not staying up before due to struts, so changed them now it does. The cargo piece that needs to sit on top of sensor is on there correctly.. I'm not sure if this could be fuses or relays. if you can help me with fuse and relay location for the top I would appreciate it.
Jumped pins 87 and 30 on relay and pump worked but noise, level of fluid is very even though I don't see any leaks. What kind of fluid and how do you add?
Jan 10, 2022 at 1:03 AM
