I have an issue with the top, it unlatches fine then the pump just runs and doesn't open. I removed the pump from its hidden place and added some fluid. Turned out one of the lines coming out of the pump which attaches somewhere has come loose. I am trying to find out where do the lines attach when coming out of the pump. There are 2 banjo bolts coming out of the pump. Each has 2 lines going out, one of the lines on the right bolt is just detached from where it should be, can't find out where it goes.
Jan 23, 2024 at 12:41 AM
