Convertible top will not open?
53,000 MILES • V6 • TURBO • 2WD • AUTOMATIC
PRRYPERRYS
  • 150 POSTS
When?
Button is pressed red light flashes.
Jun 7, 2024 at 6:22 PM
STEVE W.
  • 15,413 POSTS
When the button flashes look at the driver info center on the dash. It should show a message and a code. From there you need a dealer level scan tool that can access the body and roof control modules to access the fault data it has. There are multiple switches and sensors that could be at fault stopping it. The only other item is fuse 25 in the junction box under the glove box. It powers the top module. Beyond that you need the info from the control modules to see what they say. You will also need the scan tool to do any repairs as the top has to be placed in different positions for sensor testing which the tool guides you though.
Jun 7, 2024 at 8:55 PM
PRRYPERRYS
  • 150 POSTS
The code says soft-top module CTM I don't know what that means and how to fix it.
Jun 7, 2024 at 11:27 PM
STEVE W.
  • 15,413 POSTS
That means it sees an error in the control module that runs the convertible top. With that error you will need a scan tool or access to one that can do the testing that the OEM units can. There are not many that can handle that because BMW likes to keep things close. However, I suspect that the module will need to be replaced and programmed to work in your car.
Jun 8, 2024 at 8:10 AM
PRRYPERRYS
  • 150 POSTS
Hey, Steve. Thank you very much. I have one more question. How do I open the trunk manually? It has power but I can't open the trunk. The remote doesn't work. The button only driver side doesn't work. It has power. How do I open it manually?
Jun 8, 2024 at 12:07 PM
STEVE W.
  • 15,413 POSTS
The only way to open it from outside is the power latch. Either the button or on some the BMW logo, the only manual release that I know of is inside the trunk in case you get locked inside it. It likely doesn't unlock because of the top issue. The ECU doesn't know if the top is closed or open or partway through a cycle, so the trunk doesn't open.
Jun 8, 2024 at 2:00 PM
PRRYPERRYS
  • 150 POSTS
Good morning, my friend. I noticed the light on the dashboard shown that top is not fully closed and not fully open. It's just open a little bit and it won't close and it won't open completely it stuck.
Jun 8, 2024 at 7:49 PM
STEVE W.
  • 15,413 POSTS
That would be related to the other problems. With a scan tool it's possible to "talk" to the different modules and in most cases, you can look at the sensors as well. So, if you know that the top should show say 4 sensors as closed and 2 open when the top is fully locked but in scan data it shows 3 closed and 3 open you know to look at the sensor that is wrong.
They made the system much more complex than it really needed to be.
Jun 8, 2024 at 9:22 PM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, thank you, Unfortunately, I may have to take it to the BMW dealer. Because my scan tool won't do that. I hope it is not too expensive. I will give you an update. I'm going to try to drop it off on Monday or Tuesday.
Jun 8, 2024 at 11:01 PM
STEVE W.
  • 15,413 POSTS
Understandable. The scan tools to do these types of things are expensive and unless you plan on using them a lot, they are not a great investment. We will await the update.
Jun 10, 2024 at 7:56 AM
PRRYPERRYS
  • 150 POSTS
Okay thank you my friend I Made an appointment today. Unfortunately, it's 1 week. June 17th.
Jun 10, 2024 at 1:41 PM
