Conversion
120,000 MILES • 5.7L • RWD • AUTOMATIC
SLOBBIN
I have the car listed above and the engine seized. I have a 1986 Chevrolet Camaro which is wrecked. I want to put the engine and transmission from the 1986 into the 1978 Camaro. What problems will i face with this conversion? Also what parts will i need for this conversion to work?
Jul 29, 2016 at 7:08 AM
RIVERMIKERAT
  • 6,106 POSTS
What engine and trans do you have in the 86? The only issues I see are engine controls. The 86 might be a fuel injected engine while the 78 was carbureted. Mechanically, it shouldn't be difficult at all to swap them.
Jul 29, 2016 at 8:40 AM
SLOBBIN
Both 86 and 78 camaro are carburated and stock. The 86 is a 305 V8 and the 78 is a 350 V8
Jul 29, 2016 at 9:19 AM
HMAC300
  • 48,601 POSTS
it's a bolt in swap
Jul 29, 2016 at 9:21 AM
SLOBBIN
If anyone could go into further detail that would be appreciated. I have the tools and equipment to do this project. I just lack the knowledge.
Jul 29, 2016 at 9:26 AM
HMAC300
  • 48,601 POSTS
we can't do a step by step if you need help go to a library and check out a car manual close to the year you are working on and it will be similar. On the 86 engine wherever you are putting it the accessory brackets may be metric so save the bolts in case they are.
Jul 29, 2016 at 9:31 AM
SLOBBIN
Thank you!
Jul 29, 2016 at 9:35 AM
