This has gotten to point can't drive truck. things done and tested: carburetor o/h, Edlebrook 1405. played with jets and rods. isolated ignition circuits. start circuits, changed distributor, pick up. replaced box. compression test ,150 across all cylinders. installed ballast resistor. voltage seems a bit high out of ballast and increases as rpm goes up, even with regulator disconnected. I've been a master tech over twenty years, I am 64 Monday and had a wrench in my hand since I was about 13. I feel like I'm missing something just can't put my finger on it Thank you for any and all help.
Jun 6, 2019 at 4:42 AM
