Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
1500
Suspension
Lower Control Arm
Replace/Remove
Control arm replacement
1994 CHEVROLET 1500
196,700 MILES • 5.7L • V8 • 2WD • AUTOMATIC
TOMEMPEY41
MEMBER
1 POST
Is it possible to put upper control arm on the wrong side?
Jun 18, 2018 at 5:28 AM
Experienced Mechanic
Good afternoon.
Yes, it is very possible. The upper ball joint will be in a different location.
What is the part numbers of the control arms? I can help you identify them with the numbers.
https://www.2carpros.com/articles/upper-control-arm-replacement
Jun 18, 2018 at 9:36 AM
Add image or video
Ask a new question
Engine won't start
Transmission — Not Shifting
