Constantly blowing cold air
309,000 MILES • 6.7L • 6 CYL • TURBO • 4WD • MANUAL
TREVOR W TAYLOR
I am adding tons of coolant to the radiator. Seems to just be running through it. I have checked oil for gains. And nothing to say I have water in oil.
Where is that water going?
Nov 9, 2017 at 3:04 PM
  • 31,937 POSTS
Start with a cooling system pressure test to see if there are any external leaks, and you can do a head check. this is a simple chemical test to see if there is any exhaust gasses in the cooling system. if positive you will have a head or gasket problem, start here.
Nov 9, 2017 at 3:37 PM
