Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
RAV4
Engine
Symptoms
Misfire
Constant misfire on acceleration
2006 TOYOTA RAV4
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TONY PEREZ
MEMBER
Cylinder six misfire. I want to replace one ignition coil and all six spark plugs, but i do not know the firing order to know which is number six.
May 1, 2018 at 7:49 AM
Experienced Mechanic
I have attached a picture for you. The arrow points toward the front of the vehicle.
Image (Click to enlarge)
May 1, 2018 at 12:13 PM
HARRY P
Please see the attached image. It is a pull from Prodemand and contains the firing order and cylinder layout. Hope it helps!
May 1, 2018 at 12:15 PM
TONY PEREZ
MEMBER
Thanks for your help.
May 5, 2018 at 4:54 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
