Constant fuel but no spark
106,194 MILES • 5.9L • V8 • 4WD • AUTOMATIC
CHRIS GOULD
  • 11 POSTS
My truck has constant fuel with the key on but no spark. I have changed crank sensor, cam sensor, cap and rotor, coil. Checked all grounds and fuses, still nothing. Has no power to the coil. Please help. thanks in advance.
Aug 10, 2017 at 8:18 AM
  • 55,732 POSTS
It sounds like the ASD relay has gone bad. Here is a guide that will help us confirm the problem.
Please let us know what you find.
Cheers, Ken
Aug 14, 2017 at 2:36 AM
CHRIS GOULD
  • 11 POSTS
Have checked all fuses & relays & grounds multiple times. Still no change
Aug 14, 2017 at 2:46 PM
  • 55,732 POSTS
Lets try reading the codes to see what comes up. This will let us know if we are missing anything obvious.
Cheers, Ken
Aug 16, 2017 at 3:44 AM
CHRIS GOULD
  • 11 POSTS
Have hooked a few scanners up, unable to read anything. Through error
Aug 19, 2017 at 3:01 AM
  • 55,732 POSTS
Yep it sounds like the PCM is gone and needs to be replaced.
Here is its location, I would get a used one so its plug and play.
Cheers, Ken
Aug 19, 2017 at 3:58 AM
