constant clunking from rear hub
1990 BMW 325I
120,000 MILES • 2.5L • 4 CYL • RWD • MANUAL
R4DKO
When driving/moving a loud metallic clunking/clicking sound comes from the rear side brake hub on my car, be it forward or reverse it's a constant clunking. The sound originates from the hub area itself and not the diff. I've uploaded a video of the sound in action.
https://www.youtube.com/watch?v=5wXDgqoFFWQ
Apr 30, 2016 at 8:08 AM
CJ MEDEVAC
  • 11,004 POSTS
SOUNDS LIKE IT'S OUT ON THE END
WHEN YOUR LUG HITS THE 8 O'CLOCK POSITION IT CLICKS
MY 3 THOUGHTS
1) THE CV JOINT IS DOING IT
2) THE BRAKE PADS- REMOVE THE CALIPER AND SEE IF IT STOPS
3) THE ROTOR ONLY HAS ONE LUG IN IT, MAYBE IT IS NOT FULLY SEATED ON THE HUB OPPOSITE OF THAT LUG (THIS "WOBBLE" MIGHT ALSO MAKE THE BRAKE PADS MAKE A NOISE)/ INSTALL ALL OF THE LUGS TIGHT AND SEE IF IT STOPS (DO THIS BEFORE YOU REMOVE THE CALIPER!)
THE MEDIC
Apr 30, 2016 at 10:37 AM
