Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. We need more information to try and help you. Most of the time when you can't put the car in park it is because the shift cable has come apart internally or the shift lock mechanism is broken inside the shifter itself. I would park the car on level ground and set the parking brake, then I would remove the shift cable from the transmission and then try to put the shifter in park if so, move the transmission shifting arm into park as well. This will tell us where the problem lies. Here are instructions in the images below to help you with the problem. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
Oct 1, 2024 at 9:53 AM
