Hanging cable connector underneath the front end of the car
120,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
PCULQUI
  • 354 POSTS
There is a hanging cable connector underneath the front end of the car right below the fog lights. Could this be the cable for the left turn signal that is flashing non-stop when I ignited?
Aug 29, 2019 at 7:04 AM
  • 110,246 POSTS
Welcome to 2CarPros.
When a signal bulb is bad or something is causing power not to complete the circuit, the signal will flash double time. That is so the driver knows a bulb is not working. Based on your description, I would say there is a good chance it is related to the signal. Is it possible for you to let me know the wires' colors that are hanging or even upload a picture of what you see?
I attached a picture from the wiring schematic. It shows the wire colors to the left front turn signal. Take a look at it and see if what is hanging has the same colors.
Aug 29, 2019 at 12:39 PM
PCULQUI
  • 354 POSTS
Okay.
Aug 29, 2019 at 8:52 PM
PCULQUI
  • 354 POSTS
this is the other side. The cable should be attached as you see it.
Aug 29, 2019 at 8:54 PM
  • 110,246 POSTS
Welcome back:
It appears to be the signal wiring harness. I can see in the first pic that the bulb is broken, so that is why it is flashing so fast. It must have come loose from the light assembly.
Here are the directions for replacing the bulb. You will need to remove the headlight assembly. I will include those directions, too. It is really an easy one to do. Once the assembly is out, route the wiring the same as the other side and replace the bulb.
The attached pictures correlate with removal and replacement of the headlight assembly. The directions are for headlight bulb replacement, but it shows how to remove the assembly.
__________________________________
1999 Buick Regal V6-3.8L VIN K
Park/Turn Signal Lamp Bulb Replacement
Vehicle Lighting and Horns Turn Signals Turn Signal Lamp Turn Signal Bulb Service and Repair Procedures Repair Instructions Park/Turn Signal Lamp Bulb Replacement
PARK/TURN SIGNAL LAMP BULB REPLACEMENT
REMOVAL PROCEDURE
1. Remove the appropriate headlamp assembly.
2. Remove the rubber access cover from behind the park/turn signal lamp bulb.
3. Rotate the park/turn signal lamp socket counterclockwise to release.
4. Remove the bulb from the socket.
INSTALLATION PROCEDURE
1. Install the bulb to the park/turn signal lamp socket.
2. Position the socket to the headlamp assembly, then rotate the socket clockwise to secure.
3. Install the rubber access cover to the headlamp assembly.
4. Install the headlamp assembly.
Here are the directions for the headlight assembly. Again, these directions are for headlamp replacement, but it is the only thing I have that shows how to remove the assembly.
Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement
Vehicle Lighting and Horns Headlamp Service and Repair Procedures Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement
HEADLAMP ASSEMBLY OR HEADLAMP BULB AND/OR CORNERING, SIDEMARKER, PARK, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
pic 1
1. Raise the hood.
2. Apply light pressure to the headlamp lens to hold the headlamp assembly in place while removing the retainers.
3. Lift up the headlamp assembly retainers to release, then remove the retainers.
4. Carefully remove the headlamp assembly mounting tabs from the slots in the upper fascia support and the fender reinforcement.
pic 2
5. Disconnect the electrical connector from the headlamp assembly.
6. Remove the headlamp assembly.
pic 3
1. Connect the electrical connector to the headlamp assembly.
pic 4
2. Carefully position and install the headlamp assembly mounting tabs to the slots in the upper fascia support and the fender reinforcement.
3. Apply light pressure to the headlamp lens to hold the headlamp assembly in place while installing the retainers.
4. Align the headlamp assembly retainers over the headlamp assembly mounting tabs, then press the retainers down until fully seated.
Check to be sure that the headlamp assembly is securely retained.
5. Close the hood.
6. Check the headlamp aim, If a new headlamp assembly was installed, or if service or repairs in the front end area may have disturbed the headlamp mounting brackets. Refer to Headlamp Aiming.
Let me know if that helps you or if you have other questions.
Aug 30, 2019 at 2:13 PM
PCULQUI
  • 354 POSTS
So in the first picture, there's a bulb that is missing in the harness? I thought the bulb would be on top by where the headlamps are.
Aug 30, 2019 at 2:47 PM
PCULQUI
  • 354 POSTS
So in this picture below, what exactly am I looking at.
Aug 30, 2019 at 2:52 PM
  • 110,246 POSTS
Welcome back:
You are seeing the light socket that screws on the rear of the light housing. I believe this one takes a quarter turn to fasten and unfasten. If the bulb was replaced at one time, it may not have been secured. For some reason it came loose and dropped down.
Aug 30, 2019 at 2:58 PM
PCULQUI
  • 354 POSTS
So the picture below has a bulb missing at the end of the beige compartment. Why would there be a bulb there if the headlamps and turn signal compartments are above.
Aug 30, 2019 at 3:52 PM
  • 110,246 POSTS
Welcome back:
Please bear with me. That looks like the beige part is the light socket and at the end it looks like a broken bulb. Can you provide a picture from a different angle so I can see if from a different point of view? It looks like what I described, but now with you new question, I'm questioning myself. It could be an ambient air temp sensor or even a sensor for the airbag.
As far as why I believe it to be what I first mentioned is based on the turn signal going a different speed and not working. If it came disconnected, then the harness could have dropped down. I hope you understand.
Sorry, it's hard to tell from pictures sometimes.
I will watch for your reply.
Aug 31, 2019 at 12:21 PM
PCULQUI
  • 354 POSTS
The picture below is from the passenger side underneath the car. The 'broken side' should be the same, no?
Aug 31, 2019 at 12:28 PM
  • 110,246 POSTS
Welcome back:
Yes, that sounds correct. The one in the last picture you sent is the ambient air temperature sensor. Is it possible for you to get me a picture from a different angle so I can confirm or can you confirm that it is the same as the one in the last picture?
See picture 1. That is of the ambient air temperture sensor.
Aug 31, 2019 at 1:38 PM
PCULQUI
  • 354 POSTS
What does the ambient air temperature sensor do? Is that related the HVAC system?
Aug 31, 2019 at 9:22 PM
PCULQUI
  • 354 POSTS
Here are some more pictures. The first picture is the defective ambient air temperature sensor. The second picture is the left passenger side harness which is fine. I don't think that is a temperature sensor it is something else. As you can see, they do not look alike. What do you think it might be. Just curious. You think there are 2 temperature sensors?
Aug 31, 2019 at 10:49 PM
  • 110,246 POSTS
Welcome back:
I'm back to my original thought but with a twist. It is a light, a GE 880. Most likely a fog light. Does the vehicle have fog lights? The bulb is a fog light bulb. The glass is broken off it, but I'm certain that is what it is.
See the attached pictures. If you look at pics 1 and 2, you see the electrodes in the bulb that are partially left on yours. I circled them in the second picture. Picture 3 is the bulb in the package.
It was hard to tell in your original post, but I thought it was a bulb. That's why I needed pics from different angles to confirm. When you said there was a turn signal issue, then I suspected it was the signal bulb. Does that make sense? LOL Not being there makes it tricky, but I feel very confident that is what you have.
Let me know if the vehicle has fog lights.
Sep 1, 2019 at 11:05 AM
PCULQUI
  • 354 POSTS
Yes, thank you. Now I see what you were saying that the bulb fell off. The fog lamps haven't worked for awhile. The harness fell off the fog light compartment that's why the fog lamp compartment is loose. Maybe the previous owner started fixing it and never finished.
Thanks for all your help with this issue. I am so glad you were able to figure out the cause of the problem. A million thanks again.
Sep 1, 2019 at 1:20 PM
  • 110,246 POSTS
Welcome back:
Not a problem. I'm happy to help. Sorry it took a few tries. LOL
You take care and let us know if you every have questions in the future.
Sep 1, 2019 at 2:14 PM
PCULQUI
  • 354 POSTS
Okay. I will.
Sep 1, 2019 at 10:13 PM
PCULQUI
  • 354 POSTS
Talking about the fog lamp bulb, I purchased it and installed it. The fog lights still doesn't go on. I think it might be the fuse. Now, when I installed the bulb, I can't get it to stay tight in the compartment and I don't want to have it drop off like the other one.
Sep 2, 2019 at 2:17 AM
  • 110,246 POSTS
The light should only fit in one way and should be a quarter turn to tighten or loosen. Are you sure it is sitting flat in the light assembly? Also, if the new bulb has a rubber o-ring to keep water out, make sure the old o-ring from the old light isn't stuck on the assembly causing it not to seat.
As far as a fuse, it is in the under hood fuse box. Fuse 17 is for the fog lights. I attached a picture of it below.
Here are a few links you may find helpful:
Sep 2, 2019 at 10:51 AM
PCULQUI
  • 354 POSTS
There was a rubber o-ring on the light bulb socket I purchased. I had to remove it for it to sit correctly and was able to tighten it securely.
Now, I found the fuse #17 but it looks different than the regular fuses (red, yellow, blue ones on picture below). It's a grey box. I didn't think that was a fuse.
Does the just pull out?
Sep 2, 2019 at 9:35 PM
PCULQUI
  • 354 POSTS
On the top (picture below), there's a white arrow pointing down on top of an upper case white letter 'T'(black rectangular button).
What is that for?
Sep 2, 2019 at 9:40 PM
  • 110,246 POSTS
Welcome back:
First, I'm sorry. Number 17 is the fog light relay. The fuse is number 31.
Take a look at the attached picture.
Let me know if that helps, and sorry for the mix up.
Sep 3, 2019 at 1:10 PM
PCULQUI
  • 354 POSTS
I did see #31 but the fuse was okay.
Sep 3, 2019 at 11:12 PM
  • 110,246 POSTS
Welcome back:
Did you check of there was power to the fuse? Also, try switching the relay with one in the relay box that has the same part number and see if that chances anything.
As far as the fuse, confirm there is power to it. Also, a visual inspection usually works; however, they can look good and still be bad.
Sep 4, 2019 at 11:21 AM
PCULQUI
  • 354 POSTS
How do I check if there is going power to the fuse. Looking at the fuse, the silver metal, aluminum wiring inside is not broken or burnt. On the relay, I'll have to purchase one because there is no backup relay.
Sep 4, 2019 at 11:55 AM
  • 110,246 POSTS
Welcome back:
Basically to check if there is power, all you need is a test light. Take a look at the link above, how to check a car fuse. It explains how to confirm power is there and making it through the fuse. To help, I added some general tooling information.
Let me know if that helps or if you have other questions.
Sep 4, 2019 at 12:16 PM
PCULQUI
  • 354 POSTS
But if the fuse is not broken or burnt, there should be power, no?
Sep 4, 2019 at 1:18 PM
PCULQUI
  • 354 POSTS
Now let's say there's no power and the fuse is neither burnt or broken, how do I fix the power problem?
Sep 4, 2019 at 1:19 PM
  • 110,246 POSTS
Welcome back:
If there is no power to the fuse, we will need to disconnect the battery and remove the fuse box to identify what is damaged and causing power not to make it to that specific fuse.
Have you checked?
Sep 4, 2019 at 1:36 PM
PCULQUI
  • 354 POSTS
where is the power steering fluid reservoir in my 1999 buick regal LS and is it safe to refill it without any maintenance.
Sep 9, 2019 at 10:24 PM
PCULQUI
  • 354 POSTS
should my steering wheel be loose in park mode or should it tighten and lock?
Sep 9, 2019 at 10:28 PM
RENEE L
  • 1,260 POSTS
Hello PCULQUI,
You are asking about a different issue. Each question thread needs to about one issue. Please start a new question so that the site can properly index it. This helps other people coming to site with the same problem.
For your convenience here is the link: https://www.2carpros.com/questions/new
Make sure you are logged into the site before clicking on the link.
Thank you for using 2CarPros and have a great rest of your day!
Renee
Admin
Sep 10, 2019 at 10:35 AM
