HVAC not working properly
163,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
JOHN
HVAC works properly for 5-10 minutes, then blower motor seems to partially lose power- probably 50% less and it seams like it’s blowing through the defrost at the same time as the A/C vents. I can still make the air come out of all of the different supplies using the control. Once it starts doing this, the evaporator freezes up. The system is properly charged and has been checked for leaks. The orifice has been replaced. I also replaced the temperature actuator (89018365) and the mode control actuator (89018374), but still having the same issue. Thanks for any help or feedback!
Mar 16, 2021 at 9:52 AM
Good morning,
The evaporator freezing up is the issue. Can you give me the high and low side pressure readings while it is running to be sure the pressures are correct? The low side pressure switch should kick out the compressor before the system freezes up.
There is also a cycle switch for the compressor on the dryer that should disengage the compressor before freezing up.
Heating and A/C Operation
The purpose of the heating and A/C system is to provide heated and cooled air to the interior of the vehicle. The A/C system will also remove humidity from the interior and reduce windshield fogging. Regardless of the temperature setting, the following can affect the rate that the HVAC system can achieve the desired temperature:
* Recirculation actuator setting
* Difference between inside and desired temperature
* Difference between ambient and desired temperature
* Blower motor speed setting
* Mode setting
* Auxiliary HVAC settings
The manual HVAC system is a dual temperature zone system. There are 2 separate air temperature levers. Moving the air temperature levers to the upward position diverts most of the airflow through the heater core, which increases the outlet air temperature. Moving the air temperature levers to the most downward position diverts most of the airflow around the heater core, which decreases the outlet air temperature. The right air temperature actuator controls the duct air temperature flowing through the center console to the second row seating passengers. The air temperature offset can be as much as 16.7°C (30°F).
Pressing the A/C button enables the HVAC control module to request A/C compressor engagement and turn ON the A/C button LED. The HVAC control module sends a GMLAN message to the Powertrain Control Module (PCM) for A/C compressor engagement. The PCM will provide a ground for the A/C compressor relay enabling it to close its internal contacts to send battery voltage to the A/C compressor clutch coil. The A/C compressor diode will prevent a voltage spike, resulting from the collapse of the magnetic field of the coil, from entering the vehicle electrical system when the compressor is disengaged. Defrost and Defog mode selections will request A/C operation but not turn ON the A/C LED.
The following conditions must be met in order for the A/C compressor clutch to turn ON:
* Ambient air temperature above 2°C.
* A/C low pressure switch signal circuit is grounded.
* A/C refrigerant pressure sensor parameter is less than 3234 kPa.
* A/C compressor temperature switch contacts are closed.
* PCM receives an A/C request from the HVAC control module.
* Engine coolant temperature (ECT) is less than 124°C.
* The engine RPM is less than 5800 RPM.
The sensor information is used by the PCM to determine the following:
* The A/C high side pressure
* An A/C system load on the engine
* An excessive A/C high side pressure
* The heat load at the A/C condenser
The A/C compressor has an A/C compressor temperature switch. This switch protects the compressor from over heating. The switch interrupts power to the compressor clutch coil. When the compressor core temperature rises above 124°C (255°F) the switch opens, disabling the compressor clutch coil. When the temperature lowers to 120°C (248°F) the switch closes, enabling the compressor clutch coil. This switch is not a serviceable part, it is integral to the A/C compressor.
Once engaged, the compressor clutch will be disengaged for the following conditions:
* Ambient air temperature is less than 1°C (35°F).
* A/C compressor temperature switch contacts are open.
* Throttle position is 100 percent.
* The A/C low pressure switch is open.
* A/C high side pressure is more than 1931 kPa.
* A/C low side pressure is less than 151 kPa (22 psi).
* Engine coolant temperature (ECT) is more than 124°C.
* Engine speed is more than 5,800 RPM.
* Transmission shift
* PCM detects excessive torque load.
* PCM detects insufficient idle quality.
* PCM detects a hard launch condition.
Cycle switch
Air Conditioning Cycling Switch Replacement
Removal Procedure
1. Disconnect the electrical connector from the A/C low pressure switch.
2. Remove the A/C low pressure switch from the accumulator.
3. Remove the O-ring and discard.
Mar 16, 2021 at 10:15 PM
JOHN
I should have mentioned that the same thing happens when the heater is on, or even just the vent. Also it’s an “automatic” unit. Thanks!
Mar 18, 2021 at 1:27 AM
Okay, got it.
I still need the pressure readings as when you have automatic climate control, the A/C is on all the time.
Mar 18, 2021 at 1:40 AM
JOHN
Roy,
Here’s what I came up with:
Outside air temp: 55 degrees F
Engine off: L 55 psi/H 50 psi
AC on, fan speed 4 out 5, recirc button on, t-stat at 60 degrees F. Engine idling around 800 rpm:
Compressor off:L 19 psi/H 125psi
Compressor on: L 21 psi/H 163psi
Please let me know if you need anything else. Thank you!
John
Mar 18, 2021 at 12:41 PM
Okay, thanks.
First, with the engine off, the pressures should be exactly the same. Yours are not. You posted 50 and 55. That indicates the orifice tube could be clogged even though it is new.
The other thing is the running pressure. The low side should be 20-25 pounds rock solid. You have 19 pointing right at the orifice tube again.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Mar 18, 2021 at 7:26 PM
JOHN
Roy,
Thank you for your help! I learned that the gauges that auto parts shops loan out are not very accurate. I got readings from a shop and my Evaporator Temperature Sensor was reading 145 F instead of around 45 F. I replaced it over the weekend and it's working great now. Thanks again!
John
Mar 30, 2021 at 11:44 AM
Good job. Glad it is fixed.
You are welcome.
Always glad to help.
Mar 30, 2021 at 11:53 AM
