Conflict on Dextro 2 or SPC 111 AutomaticTransmission Fluid Montero sport
1999 MITSUBISHI MONTERO
192,000 MILES • 6 CYL • 4WD • AUTOMATIC
LSTILL
  • 6 POSTS
Hi Guys I have looked online,in manual and find conflicting information on the type of AT fluid used in the 1999 Mitsubishi Montero Sport. Mine is the 1999 XLS 3.0 enjine 4x4 4 speed AT. Seems like the 3.5 had a different Tranny that called for the sP 111 fluid. Please give me the correct fluid for the 3.0 xls 4x4. thank you
Nov 26, 2015 at 8:07 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
You need to identify which trans you have.
If you call the dealer with you VIN#, they can tell you which trans you have.
Transmission fluid
4A/T DEXRON ATF
INVECS - II 4A/T DIAMOND ATF SP-II M
Nov 26, 2015 at 11:54 AM
