Computer system removal
1988 CHEVROLET 1500
7,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
KZUELICH
  • 13 POSTS
I want to take out the computer system in this truck. This 5.7 is in a S 10 how much rewiring well there be if any?
Nov 5, 2018 at 4:46 AM
Good afternoon.
What year is the S10?
Did you replace the distributor?
Do you fuel injection or carburetor?
Nov 5, 2018 at 7:25 AM
KZUELICH
  • 13 POSTS
yes the distridutor will be replace. to a msd sytem
yes goig to use a edelbrock 600 CFM
the S 10 is a 1988
Nov 5, 2018 at 9:19 AM
You wont need to rewire anything at all.
All you need is a ignition on a signal from the fuse box for your MSD system. once you have that, there is no need for the computer system.
Nice conversion. I did a couple of these years ago and it worked out great. I used the holley pro jection system.
Take the harness for the computer system and just tie wrap it away from the engine. Wiring such as alternator, temp sender unit you need out of the harness but that is easy.
Nov 5, 2018 at 7:03 PM
KZUELICH
  • 13 POSTS
It was told to that I would need to buy the large in cap dis with vacuum advice. Is this true? Or can I get the small cap?
Nov 6, 2018 at 4:48 AM
Yes, you need the big cap distributor. The small cap is for the newer cars. It is just a cam sensor not a distributor.
Nov 6, 2018 at 5:19 AM
KZUELICH
  • 13 POSTS
What year did Chevrolet start using 700R4? Did they put them behind carburetor engine's?
Nov 29, 2018 at 11:57 AM
DANNY L
  • 5,648 POSTS
Hello I am Danny,
The GM 700-R4 transmission was introduced in 1982 and was used with carburetor engines to answer your question. Hope this helps and thanks again for using 2CarPros.
Nov 29, 2018 at 12:05 PM
Just to add, I would not use the 700 transmission. That will not hold up under pressure.
I would look for a turbo 350 or a turbo 400 transmission. They are more durable for a power conversion.
Nov 29, 2018 at 8:51 PM
KZUELICH
  • 13 POSTS
My truck is just stock. Was there a computer in those truck's? If not what did they do for lock up?
Nov 29, 2018 at 9:25 PM
Yes, there is a computer and it does control the lock up on the transmission.
That is why I suggested going to a three speed that has no computer control.
Nov 29, 2018 at 9:49 PM
KZUELICH
  • 13 POSTS
since i am going to a carb. on this truck can i put a mech fuel pump on this engine with out a return style regalator?
Jan 29, 2019 at 6:11 AM
Yes, and there is no regulator for a mechanical pump.
Jan 29, 2019 at 6:25 AM
KZUELICH
  • 13 POSTS
What should the fuel pressure be for a carburetor?
Jan 29, 2019 at 6:34 AM
The pressure should not exceed 7 lbs of pressure.Any more than that the needle and seat will not shut off fuel and it will flood.
Jan 29, 2019 at 6:50 AM
