Computer screen stays on and makes a beeping sound
40,000 MILES • 1.8L • 4 CYL • 2WD
PAULTURNER
I used to put the ignition key in and the computer screen would come on then turn off, now I put the key in and the computer screen comes on as usual, but makes a beeping sound and the screen will not turn off! Can you help please? Paul
Oct 11, 2016 at 3:53 AM
  • 31,937 POSTS
not sure as to what exactly is going on here, but the best place to start is with a scan to check for any fault codes, not all codes will set a check light, if you have access to a quality scanner, look at the instrument cluster for specific faults.
Oct 11, 2016 at 6:48 PM
