Computer replaced
133,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
5BARNDWELLERS
Old computer was blowing fuse EMC1. Purchased refurbished computer from All Source Computers, gave VIN number and mileage for "plug and play" no dealer required, according to them. Engine turned over one time only and now security light flashes and will not relearn key.
Aug 11, 2018 at 10:24 AM
Good morning.
I have had zero success with those on line PCM companies with there so called plug and play. Always had to re flash when received to get it right.
Anyway, did you perform this procedure that I listed below?
Immobilizer System Component Programming
Ten Minute Immobilizer Relearn
This ten minute relearn procedure will relearn the prerelease password and the challenge/response data between the theft deterrent module (TDM) and the engine control module (ECM).
1. Connect a scan tool to the vehicle in the pass-thru arrangement.
2. Turn ON the ignition, with the engine OFF.
3. Ensure that all power consuming devices are turned OFF on the vehicle.
4. On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions, using the Pass-Thru method. Ensure the correct programming selection is chosen based on component being replaced or programmed. For this procedure, go to the V.T.D. Vehicle Theft Deterrent Learn menu and choose the Vehicle Theft Deterrent Learn, ECM, or PK3 Replaced selection.
5. At this point the scan tool must remain connected for the duration of the 10-minute relearn procedure.
Important:
* The scan tool will initially display 12 Minutes. The first 2 minutes allow the scan tool to initialize the appropriate control module. The remaining 10 minutes is the relearn timer.
* On some vehicles the security indicator may be illuminated for the duration of the 10-minute relearn procedure.
6. Observe the scan tool, after approximately 10 minutes the scan tool will display "Programming Successful, Turn OFF Ignition". The vehicle is now ready to relearn the key information and/or the passwords on the next ignition switch transition from OFF to CRANK.
7. Turn OFF the ignition and wait 2 minutes.
8. With a master vehicle key, turn the ignition to the RUN position for 15 seconds, then start the vehicle. The TDM and ECM have now relearned the pre-release password and the challenge/response data.
9. With a scan tool, clear any DTCs.
Aug 11, 2018 at 11:50 PM
