When I go to inspection all my O2 and catalyst monitors will not complete a drive cycle?
2004 FORD F-150
227,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JEFF NEWINSKI
  • 13 POSTS
Hi, I have a problem as far as when I go to inspection all my O2 and catalyst monitors will not complete a drive cycle. I put a new battery in it, and I was told it is the PCM itself or a short in one of the wires going to the PCM. I have been trying to pass inspection since the end of 2021.
Thank you,
Jeff Newinski
Jul 3, 2023 at 7:15 AM
AL514
  • 5,668 POSTS
Hello, what codes are the PCM setting? If it doesn't pass the IM Readiness monitors for the Oxygen sensors after 2 drive cycles, it will set codes. So, there must be something stored in the PCM. If the oxygen sensor switching time or the sensors are hanging high or low voltage, it won't pass any monitors, Ill post the list of codes, but also checking the exhaust back pressure to determine any Catalytic Converter failures would be good to know as well.
But any codes we'll need to know first. That will give some direction for diagnosing the issue.
If you have a scan tool, and can check the live engine data, you can take a look at the Oxygen sensors voltage levels and see if anything looks off. If any of the oxygen sensor heater circuits are not working, it will prevent the sensors from functioning correctly. I'm not sure what kind of shop you've had it at, but they should have given you a more in-depth answer about what exactly is wrong with the PCM. Such as if the memory circuit is losing or has no power. There is a battery feed that keeps power to the PCM to retain memory, which might be something they were meaning, but they should be more specific with the issue so you can get things fixed up right, instead of just replacing a computer.
But here's the service info on the IM Readiness monitors you need. So, if the PCM is not storing any codes, which almost sounds like what is happening, you can check that the PCM's memory circuit is okay.
Here are the fuses that are permanent battery feeds that retain the memory, Fuse 29 15amp, Fuse 20 15amp, and Fuse 5 7.5amp. They are kind of difficult to see on the wiring diagram. The 6th diagram shows the PCM Grounds, if there are any broken grounding straps or corroded grounds to the frame or body, or any voltage drop from the engine block to battery negative, or the frame to the battery, this can have the same effect as a bad PCM ground. So, check those fuses for power on both sides, here are some guides to help.
We should be able to help you figure out why you're not getting the monitors passed.
Jul 3, 2023 at 9:15 AM
JEFF NEWINSKI
  • 13 POSTS
Thank you for your detailed information. I will have to take a look at the o2 sensor data.
Jeff
Jul 4, 2023 at 4:04 AM
AL514
  • 5,668 POSTS
Have any codes been stored in the PCM? There must be some, if not let me know, and do other Readiness monitors pass? As for the Oxygen sensor voltage, the Bank 1 Sensor 1 and Bank 2 Sensor 1 voltages should be swing from about 0.2 volts to 0.8volts, in that range, the Bank 1 and Bank 2 Sensor 2 oxygen sensors (these are the sensors after the Cat) should be semi steady in voltage and not be swinging in that voltage range.
Below is an example of the Oxygen sensor voltage switching, you can see the first half of the waveform is normal switching, whereas the 2nd half is a slower (lazy) oxygen sensor, it is also hanging low voltage, this is a lean exhaust type of sensor signal.
But if there are no codes setting at all in the PCM, we need to figure why, it will be checking for voltage on the "Hot at all times" fuses, If no codes are setting, that needs to be repaired first or it won't matter what the oxygen sensor voltage is, because the PCM is not storing any data.
Jul 4, 2023 at 6:19 AM
JEFF NEWINSKI
  • 13 POSTS
Hi Al514. The only stored code I had was a transmission code that is it code wise I'm no mechanic so I'm just reviewing your information multiple times I will let you know.
Thank you,
Jeff
Jul 5, 2023 at 3:28 AM
AL514
  • 5,668 POSTS
Hey Jeff, okay, what transmission code was it? The PCM controls the transmission.
Jul 5, 2023 at 3:42 AM
JEFF NEWINSKI
  • 13 POSTS
Hi AL514,
I checked the voltages of the 4 o2 sensors. They are as follows. O2b1s1 0.725 to 0.115
O2b1s2 0.745 to 0.110
O2b2s1 0.740 to 0.080
O2b2s2 0.705 to 0.085
I did not see any stored codes and he checked the fuses with a test light they were all fine. You have been my biggest help so far, I can leave it at Ford, but I am not Rockefeller.
Thanks for your time.
Jeff
Jul 5, 2023 at 11:50 PM
AL514
  • 5,668 POSTS
Okay, so, you're switching on the rear oxygen sensors, are they mirroring the front sensors in their voltage switching? If they are swinging up and down like the front 02 sensors, then it sounds like the catalytic converters are not storing oxygen and may be failing. Fords take forever to set codes, much longer than any other manufacturer. I own one too, to further check the catalytic converters, you can do a back pressure test at the front oxygen sensor locations, by removing the sensors and starting the truck for a minute to get a pressure reading, although your converters might not be at the melt down stage yet. Another test is checking the temperature at the inlet and outlet of the converters with a temperature probe. This guide will show some examples of testing. I would be interested in seeing the rear oxygen sensor voltage reading graphed such as the diagrams I posted above, those are from a scan tools live data reading the PCM. I'm not sure if you have a scan tool that can read live data or not, but comparing the front B1S1 to B1S2 voltages you can determine if the converters are not doing their job and that's why the Monitors are not passing. Same with B2S1 and B2S2 voltage. The rears ones should not fluctuate like the fronts, they should be a steady voltage, usually around 0.7v (700mv) area. Ford will charge you a lot of money to diagnose and change the converters, so it's best if you can do the diagnosis yourself.
If you want, I can explain the back pressure testing in more detail, as well as scan data if you own a scan tool
Also, have you taken a look at your spark plugs lately? Do they have carbon or soot build up on them?
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jul 6, 2023 at 4:07 AM
JEFF NEWINSKI
  • 13 POSTS
Hi AL514,
My converters are toast, the insides are all broken up. So, I guess that is what the problem is the converters are bad?
Thanks,
Jeff
Jul 7, 2023 at 5:54 AM
AL514
  • 5,668 POSTS
Yes, that is why the I/M Readiness monitors are not passing, The PCM monitors the converters by the Oxygen sensor signals, so bad broken up substrate of the converters will cause the Oxygen sensors and the Catalyst to fail those monitors, I'm sure with a restricted exhaust you had a lack of power that will return when the new converters are put on. Just FYI, the converters fail because of cylinder misfires or rich exhaust. So, if the PCM's Long Term and Short-Term Fuel Trims are higher than 10% either positive or negative, that is an issue that needs to be figured out. The fuel trims are something you will be able to read on a scan tool in the live engine data. They might be labelled LTFT and STFT in the data list.
Jul 7, 2023 at 7:42 AM
JEFF NEWINSKI
  • 13 POSTS
Okay, I will check the fuel trims and I will let you know.
Thanks
Jeff
Jul 7, 2023 at 9:55 AM
AL514
  • 5,668 POSTS
A couple last things. since the converters substrate has broken up into pieces, when replacing the them, take down the muffler and check the rest of the exhaust to verify that no pieces of the converters have gotten stuck in the baffles of the muffler, many shops never check this, but when the converter got hot enough to melt down, that break up into pieces, there is almost always sections that travel down the exhaust and get caught up in the muffler's baffles, this too causes a restriction in the exhaust, just at a different section. I have seen brand new converters put on vehicles, but because the muffler or rest of the exhaust wasn't checked, it causes excessive back pressure and can cause the new converters to overheat, damaging additional components, this being a Ford, check that the DPFE sensor has not over heated as well. The DPFE (Delta Pressure Feedback sensor) is a pressure sensor for the EGR valve, it's the sensor that has 2 tubes running down to the exhaust pipe or exhaust manifold. The sensor is usually mounted on the driver's side of the engine or on the back near the firewall, but when a converter melts down and blocks off the exhaust, these sensors being mounted to the exhaust will melt down or overheat the circuit board inside. Being that they read exhaust pressure differential when the EGR valve opens. The sensor is pretty easy to find, there are 2 steel tubes attached to the rubber tubes in the diagram below.
Jul 7, 2023 at 12:20 PM
JEFF NEWINSKI
  • 13 POSTS
Hi, I could not find LTFT or STFT I just took pictures of my live data maybe you can see it.
Thanks,
Jeff
Jul 7, 2023 at 10:51 PM
AL514
  • 5,668 POSTS
The bottom 2 in the 11st picture SHRTFT1% and LONGFT1%. the 1 stands for Bank1 of the engine, so there should be a SHFTFT2% etc., as well, was the repair done already?
Jul 9, 2023 at 6:06 AM
JEFF NEWINSKI
  • 13 POSTS
No, the truck has 227,000 miles on the original exhaust system so if I replace everything with name brand stuff it's going to be pricy. The parts market is crazy some of the stuff you buy on Amazon is knock off Motorcraft. You have been a great help, I just don't know what I should do.
Thanks,
Jeff
Jul 9, 2023 at 6:52 AM
AL514
  • 5,668 POSTS
Well, if both side Catalytic converters are broken apart inside, then they are done. I'm not sure what the inspection laws are in your state, every state is different. But you'll have to replace the Cats to get the IM Readiness to pass, as well as to pass emissions. They are both the same really, if the Check Engine light is on, it will fail. You don't need to replace the muffler and rest of the exhaust; I was just starting to inspect the rest for any pieces of the converters that have travelled down the exhaust. You can usually get them out of the muffler(s),
Take a look on Rockauto com. They have decent prices, but things get more expensive if you have a California or Federal emissions vehicle, the tag under the hood should say which one it is. California has much stricter laws when it comes to emissions. I'm not sure how accurate the scan data is on that Foxwell scan tool. I see that it's in Closed loop so it must be up to operating temperature. But I would expect the Fuel trim numbers to be more negative than they are. Did you inspect the converters yourself and see the actually broken apart? And is this the F-150 5.4L heritage edition? with or without a Turbo? If you're unsure I can look up your particular vehicle better by the VIN. I'm seeing some different service info depending on model.
Jul 9, 2023 at 10:51 AM
JEFF NEWINSKI
  • 13 POSTS
I live in the lovely state of NJ and things here are better than they used to be as far as inspections. The truck is a 04 FX4 5.4 auto 4wd non heratige or turbo and as far as the converter it was at the dealer getting a new exhaust manifold and they said the converter on that side was bad. I just shrugged it off, they wanted 900 bucks for a new one but when you brought up all this information about how it could be my converters and not my PCM I was amazed I finally got the answer to my problem.
Thanks,
Jeff
Jul 9, 2023 at 11:38 AM
AL514
  • 5,668 POSTS
Yeah, the OEM will always be super high for stock components. rockauto has some for around 250 and higher. What was wrong with the exhaust manifold? Was it cracked or broken? I just want to figure out why that side converter went bad.
https://www.rockauto.com/en/catalog/ford,2004,f-150,5.4l+v8,1422751,exhaust+&+emission,catalytic+converter,5808
Jul 9, 2023 at 12:37 PM
JEFF NEWINSKI
  • 13 POSTS
Studs on the manifold were broken and it was leaking bad so I got it fixed thinking NJ inspection would fail me. Well, that's when all this crap started at the end of 2021so my trucks been messed up a while.
Thanks
Jeff
Jul 9, 2023 at 1:04 PM
AL514
  • 5,668 POSTS
If the exhaust manifold was leaking then the oxygen sensor on that bank was reading lean when it shouldn't have been, and that's what probably caused the converter to fail, too much fuel down that bank of the exhaust, overheated the converter and sent it into meltdown, then they break apart into pieces. So, that's what I think caused that failure. Usually, it's a misfiring cylinder causing the same thing, too much fuel going down to the converter overheating it, and bam. meltdown. A leaking exhaust manifold is a logical reason for that converter's premature failure.
Jul 9, 2023 at 3:59 PM
JEFF NEWINSKI
  • 13 POSTS
Well, needless to say the old converter was put on at the time of the repair and I never thought it was going to be the thing that was messing everything up as far as the computer readiness. I have been to so many mechanics for answers and they all were wrong.
Thanks,
Jeff
Jul 9, 2023 at 10:52 PM
AL514
  • 5,668 POSTS
Sorry it's been such a difficult time for you. I'm not sure why "mechanics" can't look up some service info. We have a lot of great technicians on here, so if there's a question, I can answer one of the other guys will definitely be able to. The Catalyst monitor can't pass if the PCM sees the rear Oxygen sensor voltage mirroring the front Oxygen sensor on that Bank of the engine. That tells the PCM that the converter on that side is not burning off the left-over hydrocarbons and CO. The hydrocarbons are raw fuel, and the CO (carbon monoxide) is partially burned fuel, both are a byproduct of combustion engines. So, when the converter is doing its job, the rear oxygen sensor should have a steady voltage reading.
Jul 10, 2023 at 8:48 AM
JEFF NEWINSKI
  • 13 POSTS
You have been a big help. Thank you so much for your help. I'm sure I will have more questions about other things popping up here and there with my truck.
Thanks,
Jeff
Jul 10, 2023 at 9:00 AM
AL514
  • 5,668 POSTS
No worries, I'm glad we could help. Hope the repairs go okay.
Al
Jul 10, 2023 at 9:32 AM
JEFF NEWINSKI
  • 13 POSTS
Thanks, me too.
Jeff
Jul 10, 2023 at 10:29 AM
