Computer not learning crank position sensor?
211,678 MILES • 3.6L • V6 • 2WD
H_OUSTA2
I have a message after the car had been running for around 15 minutes saying: oil pressure low stop the engine). I have replaced the PCM in the car because I got code p062 ECU error. I got PCM refurbished and reprogram with vin number.so here I got check engine light and code P0315 crank shaft position sensor not learned. What is going on with this car? are the computer needs to be programmed being installed on the car or is the computer is bad?
Oct 8, 2024 at 10:17 AM
  • 55,721 POSTS
can you please double check the code #, code p062 is missing a digit. Also, there is no crankshaft relearn for this car, here are the instructions and they mention it. Check out the images (below). Let me know the other code please.
Oct 9, 2024 at 3:26 AM
H_OUSTA2
Hi, I thank you for your information and the code is p062f internal control modula EEPROM ERROR.
Oct 9, 2024 at 10:00 AM
  • 55,721 POSTS
Yep, that is the problem then, the PCM is not programmed correctly. I would try it again. Here is the correct way to replace the PCM in case you need it. Check out the images (below). Please let us know what happens.
Oct 10, 2024 at 4:50 AM
