Computer glitch
91,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
GLEN STEVENSON
car runs fine for little while then with no warning locks start clicking parking lights start blinking and car will not accelerate spits a sputter's. put car in parking seems fine no locks no lights car revs fine as soon as you put it in any gear it starts with the lights and locks.
Apr 30, 2017 at 11:37 AM
HMAC300
  • 48,601 POSTS
make sure battery is good and has been load tested most places do for free. this includes battery terminal ends are clean.then check fuses and finally have a mechanic scan for codes. also, have belt and tension-er checked as recommended replacement is 60,000 miles for both. any oil or antifreeze on belt destroys it.
May 1, 2017 at 12:07 AM
GLEN STEVENSON
Battery has been checked and is good voltage while running is between 13.8 and 14.5. scanned car no codes only lights on are traction control and ABS needs speed sensor right front.
May 1, 2017 at 12:51 AM
  • 55,711 POSTS
It sounds like you have a battery cable that is going bad. With the key on try moving the cables around to see if you can get it to act up.
Cheers, Ken
May 3, 2017 at 3:56 AM
