Computer Command Ride Relay / Load Leveler Relay
1996 OLDSMOBILE 98
122,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
LIZARDKINGED
  • 5 POSTS
I cant find this item. Supposedly its located in a standalone unit underneath drivers side car seat, but under the carpet or something.
I installed passive struts and have yet to put the continuous rate springs on, which causes my compressor to run and run and lower my battery... I need to find this Relay/fuse.
Jan 26, 2015 at 2:20 AM
CADIEMAN
  • 3,544 POSTS
hi again u have to remove the whole seat to get under the carpet properly. i would just unplug the compressor and the height sensor on the rear end.
Jan 26, 2015 at 2:44 AM
LIZARDKINGED
  • 5 POSTS
Oh man. Well are you aware of which side it's under. Frankly I'm sick of dealing with it. Pretty car, good condition. I just need the compressor to not run. It will just throw the error code at startup right?
Cause those errors just go away when you hit "reset" from bad tail-lights, to the date being messed up from an after market CD player. The codes are still there, just not flashing in the consol.
That about sums it up correct?
Jan 26, 2015 at 3:02 AM
CADIEMAN
  • 3,544 POSTS
TRY UNPLUGGING THOSE TWO THINGS. THAT WILL STOP IT NO CODES
Jan 26, 2015 at 3:25 AM
