Computer clearing
1999 BUICK PARK AVENUE
187,000 MILES • 3.3L • V8 • 2WD • AUTOMATIC
BIG OAK TREE
How do I clear the computer?
Mar 22, 2019 at 4:28 AM
SCGRANTURISMO
  • 4,897 POSTS
I assume you are talking about clearing the Direct Trouble Codes (DTC)s out of the Powertrain Control Module (PCM) AKA, "computer". The best way is to use a code reader and go to the "Clear DTC" option and do it like that. The second, and less approved, but highly effective way, is to unhook the negative battery cable from your battery for five minutes. This will completely clear your Keep Alive Memory(KAM) from the PCM. Let us know if there is anything else we can help you with.
Thanks,
Alex
2CarPros
Dec 7, 2020 at 7:29 AM
