No spark after shorting out heat sensor plug wire
290,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DONALD RIVAS
  • 6 POSTS
Hi all, I accidentally shorted out the wire in the heat sensor plug and the fuel pump started running and pumped the manifold full of fuel. I then fixed the computer tracks that was burnt off and now I cannot get spark.
Sep 16, 2018 at 6:23 AM
  • 55,710 POSTS
When you say heat sensor plug do you mean the engine coolant temperature sensor? Shorted to ground, sparks? Have you checked all fuses? Here is a guide to help:
Cheers, Ken
Sep 18, 2018 at 3:46 AM
DONALD RIVAS
  • 6 POSTS
Hi Ken, yes I connected a wire to the earth in the plug that connects to the temperature sensor and it touched the positive on the battery by accident.
Greetings, Donald
Sep 18, 2018 at 5:33 AM
  • 55,710 POSTS
Oops, yep it might have taken out the PCM they do not like that. If all fuses are okay I would try a used PCM to see what happens. Please let me know.
Sep 19, 2018 at 9:25 AM
DONALD RIVAS
  • 6 POSTS
Thanks Ken, will do.
Sep 19, 2018 at 3:57 PM
  • 55,710 POSTS
Sep 20, 2018 at 9:00 AM
DONALD RIVAS
  • 6 POSTS
So far I am changing the writable chip just waiting for stock.
Sep 20, 2018 at 9:02 AM
DONALD RIVAS
  • 6 POSTS
Ken, I am also busy with a Fiat Palio. After battling with sensors I got to clear all diagnostic codes but now the idling stays up and down between 1,500 and 2,500 rpm's and I have also got an earth leak on the lights. When I set brake lights on the flickers stop working but light stays on and the tail light goes dim. No fault in the wiring. Where do I look now"
Thank you,
Donald
Sep 20, 2018 at 9:11 AM
  • 55,710 POSTS
Can you start a new question for this different car so we keep the subject matter clean. Please post your new question here, you must be logged in:
Cheers, Ken
Sep 20, 2018 at 9:25 AM
