Computer
163,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
WORTHIN52
  • 35 POSTS
When removing the ECU / ECM does it come out of the firewall on the engine compartment side or does the dash have to be removed? When a new ECU / ECM are installed does it have to be programmed? Do you know of any videos that show how to replace the ECU / ECM?
Jan 21, 2016 at 10:48 AM
WRENCHTECH
  • 20,760 POSTS
It comes out from the engine side.
Jan 21, 2016 at 10:49 AM
WRENCHTECH
  • 20,760 POSTS
Yes, it does have to be programmed in the vehicle before it will run.
Jan 21, 2016 at 10:50 AM
WORTHIN52
  • 35 POSTS
How difficult is that to do. Is it possible I can do that myself using my laptop? Do you know of any videos that explain how to program the computer?
Jan 21, 2016 at 11:50 AM
WRENCHTECH
  • 20,760 POSTS
No, you can't program. Mosty repair shops can't even do that.
Jan 21, 2016 at 5:58 PM
WORTHIN52
  • 35 POSTS
That doesn’t make sense. Then how do you program a new ECU / ECM?
Jan 21, 2016 at 11:51 PM
WRENCHTECH
  • 20,760 POSTS
You first purchase a $10,000 scan tool. You then pay a subscription fee to the manufacturer to have access to the software and then you go to some very advanced training to learn how to do it without locking up the computer.
Jan 22, 2016 at 12:27 AM
WORTHIN52
  • 35 POSTS
That’s insane! Do dealerships have the equipment and know how to program them? I’m guessing you would have to get a second mortgage on your home to pay for it.
Jan 22, 2016 at 12:54 AM
WRENCHTECH
  • 20,760 POSTS
Yes, the dealers all do that and the average cost is about $100. Even when most independent shops replace a computer, they have to tow it elsewhere to have it programmed.
Jan 22, 2016 at 12:56 AM
WORTHIN52
  • 35 POSTS
If there is something wrong with the ECU / ECM. Is it possible that cold weather could cause problems?
Jan 22, 2016 at 1:04 AM
WRENCHTECH
  • 20,760 POSTS
I have no idea what issues you have with your car or computer. Like any electronic circuit board, the computer can be effected by temperature changes, but even if it is, that is still a defect in the computer.
Jan 22, 2016 at 1:27 AM
