compressor belts slipping
LWARNOLD
is it a diy mech job to adjust compressor belts ,if so instructions would be much appreciated
thankyou
Apr 20, 2013 at 3:05 AM
KHLOW2008
  • 41,812 POSTS
Belt adjustments are DIY possible but some belts have autotensioners meaning no adjustment is possible nor required. If the belt is loose it has to be replaced.
https://www.2carpros.com/articles/how-to-change-a-serpentine-belt-video
If belt is adjustable, look for a pulley that is running along the A/C compressor and crank pulley belt. It would have a holding nut that needs to be loosened before you can turn the adjuster bolt at side for adjusting belt.
Apr 20, 2013 at 6:06 PM
