What is the proper compression rating when doing a compression test?
Dec 16, 2016 at 10:16 PM
HMAC300
✓Experienced Mechanic
all cylinders should be within twenty percent of each other compression varies due to compression ratio but you need at least ninety psi to run right on all cylinders.
