Engine wont start What should the compression psi be at?
138,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JSALZ
  • 13 POSTS
Feb 18, 2017 at 1:51 AM
  • 55,721 POSTS
With this many miles the compression should be between 125 and 140.
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
May 31, 2021 at 5:45 AM
JSALZ
  • 13 POSTS
1994 ford f150 has spark fuel pressure and compression and still no start
  • 55,721 POSTS
Are the injectors getting a trigger signal? Here is a guide to help you test the problem.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please let us know what you find.
Best, Ken
JSALZ
  • 13 POSTS
Has little vacuum pressure, all hoses are connected. It runs fine with mass air flow sensor unplugged, changed it cause I thought it was the problem but wasn't. Getting fuel pressure, any suggestions?
  • 55,721 POSTS
Lets run the trouble codes to see what the computer says,
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Please let us know happens.
Best, Ken
