Replacing a timing belt. how do I know if I'm on the compression stroke on the camshaft?
Sep 11, 2025 at 6:57 AM
✓Experienced Mechanic
If the timing mark on the camshaft gear is on the mark you are on the compression stroke, check out the red arrow. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Sep 12, 2025 at 2:35 AM
EUGENE BEROS
MEMBER
Lined up the timing marks and the engine doesn't start. What should I check now?
Sep 12, 2025 at 10:17 AM
I would check for compression, this video will help:
