No and low compression
800 MILES • 4.0L • 6 CYL • AUTOMATIC
KIMBAFOUR
No compression number five cylinder and low compression in other five cylinders. Supercharged engine.
May 14, 2018 at 12:48 AM
KIMBAFOUR
Yes this is correct. Thank you.
May 14, 2018 at 12:52 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Perform a cylinder leak down test of number five. What it does is apply air to number five cylinder when it is up at TDC when both valves are supposed to be closed and check for a leak. If you can hear air coming out the tailpipe then the exhaust valve is not seating. If air is heard back out the intake manifold or throttle opening, then the intake valve is not seating. If air is heard when you remove the engine oil fill cap or dipstick, then the piston rings are leaking or a blown head gasket, and if air bubbles are coming up in the radiator when you remove the radiator cap, then a blown head gasket.
As far as the others go, you never mentioned the readings but if you squirt a little motor oil into the cylinder and it goes up more then the piston rings are worn.
May 14, 2018 at 1:50 AM
KIMBAFOUR
Thank you for the information you sent, very helpful! The rest of the cylinders are low other than number five being 0 psi the other five are 90-110 psi. Does make a difference? Thank you, Scott
May 14, 2018 at 4:44 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
They are low, normally the minimum is like around 120 psi. Well, if it turns out to be the rings for number five anyhow, you may want to just do them all.
May 14, 2018 at 6:46 AM
