Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Rendezvous
Climate Control
Air Conditioner
Compressor
Compression
2005 BUICK RENDEZVOUS
100,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
AARON BLACQUIERE
MEMBER
I have 190 lbs on cylinders one, three and five and 150 on two, four and six what could cause that and what is the compression supposed to be?
May 4, 2018 at 11:28 PM
Experienced Mechanic
Good morning.
The compression is within specs. Considering the age of the vehicle and mileage, it is good.
The difference may be from work performed at one time whether it was a head gasket on valve job.
It will not effect the operation of the engine at all.
The spec is 140-165. the 190 is a little high but that could be the result of carbon build up.
Do you have a concern?
May 4, 2018 at 11:49 PM
AARON BLACQUIERE
MEMBER
What is the best way to get rid of carbon build up without tearing down the head?
May 5, 2018 at 1:21 AM
A product call Seafoam is a good product.
Also, GM top engine cleaner is another good one for carbon build up.
May 5, 2018 at 5:38 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
