Component location
210,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
DILLIAN
I was told by a friend of mine that the problem to my issue is my cam sensor and I cannot find the location anywhere for my cam sensor can you tell me where it is located
Feb 15, 2016 at 7:11 AM
HMAC300
  • 48,601 POSTS
you don't have one just a distributor with an ignition module and pick up coil
Feb 15, 2016 at 7:27 AM
WRENCHTECH
  • 20,760 POSTS
I guess that would depend on what engine it has. If it has a 3.1 it won't have either of those things.
Feb 15, 2016 at 7:53 AM
DILLIAN
Awesome sorry I found out shortly after I wrote the question my other question is.do I need a new distributor.having problems running, driving after about 30 minutes of run time after engine warms up and gets to operating temp I'll go for a drive and out of nowhere it dies and that's only when engine is hot
Feb 15, 2016 at 10:10 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it
Feb 16, 2016 at 8:22 AM
DILLIAN
No Schrader valve on the rail
Feb 16, 2016 at 7:45 PM
HMAC300
  • 48,601 POSTS
if you have tbi you won't have you'll have to put an adapter on it to read it you should have 9-13 psi.
Feb 17, 2016 at 1:58 AM
DILLIAN
Ok and just an update what will fuel pressure tell me ? Or why am I checking it I should ask
Feb 17, 2016 at 10:52 AM
HMAC300
  • 48,601 POSTS
low fuel filter causes some codes to set and if low can cause engine to not run correctly
Feb 17, 2016 at 10:41 PM
