Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Drivetrain
Transmission
Interchange
Compatible transmission
2000 CHEVROLET BLAZER
185,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
TATVAL69
MEMBER
1 POST
Transmission has a grinding noise and will not shift past second gear into third gear. What other transmissions are interchangeable?
Aug 2, 2018 at 10:16 PM
Experienced Mechanic
Good morning.
What transmission do you currently have?
Aug 2, 2018 at 11:47 PM
There is only one listed for your truck. The chart is attached.
You could replace it with other GM transmissions but wiring will have to be replaced to make it work as well as flashing the PCM to see it.
Image (Click to enlarge)
Aug 2, 2018 at 11:51 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
