Compatible parts
10,699 MILES • 4 CYL
ROSAMILINDA
I have the car listed above it is the wagon SW2 and I need to replace the tension pulley. Is a pulley from a 1999 Saturn SL compatible?
Oct 1, 2017 at 8:30 AM
CJ MEDEVAC
  • 11,000 POSTS
This would be an easy and fast way to check for compatibility of parts.
https://www.2carpros.com/questions/alternator-77779483
Let us know if it works for you.
The Medic
Oct 1, 2017 at 9:11 AM
STEVE W.
  • 15,408 POSTS
Same tensioner is used on both versions of the 1.9 used that year.
But I do not like to use a used tension-er, they get weaker as they age and the one you put on may be worse than the one you already have. Now if it was just replaced a while ago it is likely okay.
Oct 2, 2017 at 3:21 PM
