Compatibility
96,000 MILES • 4.8L • 4 CYL • 2WD • AUTOMATIC
GERRY ANDERSON
Will a 2010 Volkswagen Golf gti 4 pin male with a female connector fit my 2015 Volkswagen Beetle 4 pin male with female connector? Both drivers side. The switches look identical!
May 2, 2020 at 9:20 PM
Just to clarify, are you just taking the connector off and going to solder the wiring to the existing wiring? So you are just looking to use the connector itself? If this is the case, then as long as it connects to the other side of the connector then you are find to use it.
If I am misunderstanding something please let me know. Maybe just get a picture of the connectors that you are looking at and we can go from there. Thanks
May 3, 2020 at 2:32 AM
