Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Passport
Exterior Light
Headlight
REPLACE/REMOVE
Headlamps compatibility
1999 HONDA PASSPORT
200,003 MILES • 3.2L • V6 • 4WD • AUTOMATIC
ANGEL0324
MEMBER
Can the headlamps front a 2001 Honda passport fit in a Honda passport 1999 if I change the grille too?
Dec 30, 2018 at 6:59 AM
Experienced Mechanic
Even if you are able to mount the grill and headlight assemblies, the bulbs are different and the wiring/connections are different.
I wouldn't recommend it.
Dec 30, 2018 at 2:51 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
