Would you be able to tell me if I could use a c6 out of a 96 f250 and make it work in a 77 f150? Both are big block 4x4's. Is there a difference?
Feb 12, 2016 at 7:51 AM
JOHNNYT73
✓Experienced Mechanic
There is bit of difference. Newer trucks require more information from other sensors such as engine coolant temp sensor, and such for proper shifting and operation. Older transmission worked primarily just on fluid pressure. Check around the net for any info specific to your concern.
Feb 12, 2016 at 9:13 PM
DERKENDALL
MEMBER
Thank you Johnny. That's what I was thinking and what I was afraid of.
Feb 12, 2016 at 10:29 PM
HMAC300
96 ford's don't use a c6 anyhow, you need one from a compatible year like yours you can use a 2wd and replace the shaft with a 4wd shaft
