thermostat replacement
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ALLIE KATT
I replaced the thermostat and hose on my car now it's leaking from the housing. I can't afford a new housing unit. Is there any cars that are compatible with the car I have?
Dec 21, 2018 at 6:25 AM
  • 110,248 POSTS
If the thermostat is leaking, chances are it just needs resealed. As far as other vehicles compatibility with your vehicle, you would have to actually look at them to confirm they are the same. It seems like everyone of them are different in some way.
Now, can you tell me where it is leaking from? Is it the hose, where the housing mounts, or is the housing cracked? Also, when you installed the new thermostat, was the housing and where it mounted clean and dry? Are you sure the thermostat was properly positioned prior to installing the housing? Was the gasket/o-ring in good condition?
Here is a link that shows how in general one is replaced. Make sure you followed these directions.
Here are the directions specific to your vehicle for replacement. Read through them to confirm you did everything it shows. The attached pictures correlate with these directions.
______________________________
PROCEDURES
Removal
1. Drain the cooling system.
2. Disconnect the thermostat hoses.
3. Remove the thermostat cover.
1 Remove the three bolts.
2 Remove the cover.
4. Remove the thermostat.
Installation
1. To install, reverse the removal procedure.
2. Refill the cooling system.
Let me know. If you plan to get one from another vehicle, it will have to be the same model year, engine, and then you would have to confirm it is the same.
Let me know if this helps.
Dec 21, 2018 at 9:41 AM
ALLIE KATT
Yes, I cleaned and dried the housing area and the gasket is new. I put it in correctly. Lol It is not a difficult replacement. No I don't believe it's coming from the hose because I replaced the hose that goes from the radiator to thermostat housing. I think the housing my be cracked where I can't see it. I'll send a video a little later.
Dec 21, 2018 at 9:00 PM
  • 110,248 POSTS
Welcome back:
It sounds like you have the same luck as me. lol If you can, pressure test the system to help determine where the leak is coming from. Here is a link that shows how it's done. I realize most people don't own a pressure tester, but nearly all parts stores will lend one to you with the hope of selling parts.
https://www.2carpros.com/articles/radiator-pressure-test
If you find the housing is leaking, price an aftermarket one. Companies make them really cheap. You could also check on line. I replaced a coolant flange for a customer on a VW a week ago. The part was $20.00 at the parts store, but he found it online (and I'm not making this up) for $2.95 plus shipping. Total was $4.95. There are a lot of aftermarket manufacturers such as Dorman, Mahle, National, that make great products at excellent prices.
Regardless, let me know what you find. However, I do suggest pressuring the system to confirm where the leak is coming from. It could be something as simple as a hose clamp; especially if you reused the old ones.
Take care and let me know if I can help.
Dec 22, 2018 at 3:34 AM
PATRICKWEAVER2008
1999 Ford Contour 4 cyl Front Wheel Drive Automatic
How to change the Thermostat and where is it located
Feb 9, 2021 at 4:22 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_532.jpg
Disconnect the camshaft position sensor electrical connector. Disconnect the coolant hoses and position to one side. Unscrew (3)bolts and remove the thermostat housing
TWALSH
where is thermostat located, how difficult to change?
BMRFIXIT
  • 19,053 POSTS
V6 2.5Lengine disconnect battery ground terminal drain coolant system remove air cleaner remove engine plastic cover disconnect hoses remove thermostat housing remove the two bolts separate the hosing remove and replace thermostat
https://images.2carpros.com/forum/automotive_pictures/99387_25count_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_25_count_1.jpg
ROSIETOES
My thermostat was not reading any temp for 2 week then it ran halfway upon starting it and climbed to just under hot. I got a new thermostat installed by a mechanic and it still reads halfway when I start my car. It doesn't go down to cold. Can I drive with it reading halfway upon starting and hot while driving?
Feb 9, 2021 at 4:23 AM (Merged)
  • 110,248 POSTS
has the sending unit been checked?
ROSIETOES
I dont know actually.
  • 110,248 POSTS
The temp sending unit is what sends the info to the gauge. It sounds like it may be the problem. Check wiring to make sure nothing is damaged.
ROSIETOES
i replaced the thermostat again it fixed it
Feb 9, 2021 at 4:24 AM (Merged)
  • 110,248 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
JMD1984DAWGS
i was wanting to know how to change the thermostat on the ford contour its a 1995 model can you please help me
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to help you see what you are in for when doing the job.
Check out the diagrams (Below) both engines
Cheers
STORMBRINGER1
I want to change my thermostat but I am unsure which part of the housing do I remove the part that is attached to the block with the sensor or the part that is attached to that with the two hoses their is three bolts on the housing but the bottom one is blocked by a clamp having a hard time getting it to move it is a spring clamp.
HMAC300
  • 48,601 POSTS
The location of the thermostat is :
On the engine end of the upper rad hose. Make sure when you replace it the spring goes toward the engine.
the clamp needs to be squeezed together and reused, ther eis special tool for that try an auto parts for rental
