car was idling with the air conditioner on when it starts to shake and the check engine light came on
102,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
Today the car was idling with the air conditioner on when it starts to shake and the check engine light came on.
I checked the codes there were I think nine of them. The one I remember are U0001, U0140, p700. The car ran fine since August 7, 2016 until today. Today I wiggled PCM connector #4 the car did not starts and the security light was flashing, the battery light came on too. I had to disconnect the negative battery after that the car started.
Oct 1, 2016 at 1:38 PM
HMAC300
  • 48,601 POSTS
with the U codes this needs to be checked by a mechanic because modules are not reading each other like they should. you could have a bad or weak battery as that will cause multiple codes . most places can check for free including a load test.
Oct 2, 2016 at 12:56 AM
ZEMORZEMOR
  • 486 POSTS
I checked the battery and charging system it is good.
Whats the next step please to diagnosis/
Oct 2, 2016 at 11:48 PM
HMAC300
  • 48,601 POSTS
take to a mechanic so he can hook up his scanner to see what is wrong. It needs to checked with a professional grade scanner.
Oct 3, 2016 at 2:18 AM
