Common Transmission issues
64,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1
  • 410 POSTS
I always see Ford Focus cars with transmission announcements. Are these CVTs? What is a common problem that happens with these cars?
Jan 28, 2022 at 11:01 PM
SQM
  • 6,383 POSTS
These are not CVTs.
The main issues are with the duel clutch automatic transmissions for these vehicles.
The dual clutch transmission is an option on the lower trim focuses and standard on the titanium.
Typical issues are jerking and getting stuck in gear. They do become noisy as well.
The standard automatic transmission does much better in terms of reliability.
I am attaching some of the info below about what I am referring to. This is a TSB from Ford on the 6PS6 transmission.
So, do you know which transmission that Focus has?
Let me know if you have any questions.
Jan 29, 2022 at 1:46 AM
BHAMDOC1
  • 410 POSTS
How can i tell which it has without driving? 1FADP3F27GL354474
Jan 29, 2022 at 2:08 AM
SQM
  • 6,383 POSTS
The best course of action would be to call your local Ford dealer and provide them with the VIN. Typically you can talk to the parts department, they will be able to look up and tell you which transmission the vehicle is equipped with.
Jan 29, 2022 at 9:58 AM
