bypassing the column dimmer switch?
100,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BOBBYB66
I would like to bypass the headlight dimmer switch on my car listed above. No matter how I try to get it to work from the switch it keeps getting stuck. I have torn it apart several times and got it working then after a couple days it messes up again. I would like to bypass to floor switch. But the floor switch has 3 wires. The car has 4 wires. There is yellow wire with black stripe, yellow wire, green wire, and I believe a tan wire. So, I need to know how to wire it.
Aug 6, 2023 at 4:41 AM
  • 55,691 POSTS
You can connect the yellow and grey wire together; this will bypass the dimmer. Check out the images (below). Please let us know how it goes.
Aug 7, 2023 at 4:48 AM
BOBBYB66
Thank you, I will give it a try this weekend when I get some time off.
Aug 7, 2023 at 10:22 AM
