Collision Avoidance System?
78,880 MILES • 4.6L • V8 • TURBO • 4WD • AUTOMATIC
CHARLESTUCK
  • 66 POSTS
Sometimes the car applies the brakes regardless of the following distance.
Mar 12, 2026 at 2:34 PM
  • 55,711 POSTS
I would do a CAN scan first before replacing anything, but to me it sounds like the proximity sensor in the front of the car is bad. Here is a video to show you how to do the first step.
CAN SCAN - https://youtu.be/u-4syLc-ifQ
Problems can occur if:
1. Dirt or bugs cover the sensor
2. The grille/emblem area is dirty
3. The bumper has been bumped or repaired
4. Radar alignment is off
The radar may need recalibration with a scan tool and target board, or the sensor itself is bad but the scan should have a code for it. Please let me know what you find, Ken
Mar 13, 2026 at 2:59 AM
CHARLESTUCK
  • 66 POSTS
Scan produced no problems.
Jul 15, 2026 at 8:05 PM
  • 55,711 POSTS
To confirm it was a CAN scan correct, not a regular drivetrain scan? There are different. Also, I would heck the sensor in the front to make sure it is not dirty or has something in front of it. Can you see the sensor?
Jul 16, 2026 at 6:28 AM
CHARLESTUCK
  • 66 POSTS
There were no errors. How do I access the camera in the grill behind the plate? I want to clean it.
Jul 16, 2026 at 9:45 AM
  • 55,711 POSTS
Yep, sorry about, my bad, that system does not use a camera, it has two detection units in the front bumper, has the car been in an accident? Check out the images below.
Jul 16, 2026 at 11:40 AM
