Cold start issues/running rich
123,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
PUGLAS868
I am throwing all types of codes p0171, p0174. After I removed and plugged vacuum lines going to sensors on EGR it threw a p0106. Smoke tested intake manifold resulted in EGR leak placed in a block off plate to see if it helps threw p0108 and p0109. I know there is sensors on top of the EGR that measures exhaust and intake gasses. I am trying to throw as many related codes as possible to determine faulty EGR. I was wondering if my solution of a brand new $180.00 EGR is it MAF was replaced.
Dec 8, 2018 at 9:36 AM
  • 55,732 POSTS
It sounds like you have a partially clogged catalytic converter. To confirm the issue check out this guide:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Cheers, Ken
Dec 10, 2018 at 8:45 AM
