Cold stall
2008 MAZDA MX5
50,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
LIAMAUSTIN24
I have a 2008 NC Miata, and when driving the engine stalled twice in a row, while cold after idling for about thirty seconds. It's about 3 degrees Celsius (UK).
Will this do much harm? The car now drives and starts fine.
Thanks
Mar 28, 2019 at 1:31 PM
SCGRANTURISMO
  • 4,897 POSTS
Three degrees Celcius. I'm not sure how cold that is but I doubt very seriously that it will affect your vehicle at all. You have nothing to worry about. How is it over there? I have never been to United Kingdom, but I've always wanted to. Maybe someday. Please let us know if there is anything else that we can help you with.
Thanks,
Alex
2CarPros
Mar 28, 2019 at 5:15 PM
  • 55,433 POSTS
This sounds like the car is going into limp mode due to a dirty throttle bore. Here is a guided that will help you fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
Do you have check engine light on if so let's get the codes.
Mar 29, 2019 at 5:10 AM
LIAMAUSTIN24
Hi guys, thanks for the reply. 3 degrees Celsius is about 38 degrees Fahrenheit. I was worried about having to start the engine cold 3 times, wearing the components.
I don't have any other issues with power at all, I believe it was just human error on my part - and was more worried about what kind of wear this would cause on the engine on occasion.
The car is modified with a full decat exhaust and manifold, air induction kit and tune - putting out about 185bhp and drives well otherwise.
Thanks again
Mar 29, 2019 at 6:13 AM
  • 55,433 POSTS
Just allow the engine is warm up before you drive it you should be fine. Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 30, 2019 at 3:47 AM
