Engine wont make heat 70 degrees on scan tool at 45 below 0 190 thermostat not opening at all two different stock pumps. this is diesel 6 ramp 70hp over stock injectors 5in exhaust trying to find problem last three or four years modified one water pump cut impellers down restricted floe through transmission cooler no engine fan. only comes up to about 130 degree thermostat still not opening top rad hose 80 degrees on temperature scanner tool. Seventy five years young still driving eighteen wheeler and quad dump raced and built motors in 1970's circle track also diesel mechanic gateway trans semis Chicago.
Feb 28, 2019 at 11:26 PM
